A question for you electric choke guys - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 06-03-2008, 06:47 PM
I have decided to wire it up to a 12volt switched ignition source without a relay. I found an extra 12v wire that is switched power which I am going to use and run a manual on/off switch in the wiring as well. I really need to figure out this oil sensor crap because the connector I have in my car is 1 terminal and the sensor the parts store sold me has 2 terminals.
The joys of hotrodding
  #32 (permalink)
Old 06-03-2008, 07:10 PM
shortyforty's Avatar
Last journal entry: V8 suspension added
The electric choke wire on my 85 Mustang 5.0 goes to the field terminal of the alternator.
  #33 (permalink)
Old 06-03-2008, 08:17 PM
Think of a 2 terminal oil sender as a toggle switch. That is basically what it is an
On/Off switch that is switched by oil pressure. A one wire oil sender would be for just an oil gauge. And a 3 wire oil sender would be a combination of the two above stated oil senders.
  #34 (permalink)
Old 06-03-2008, 09:43 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I worked for Ford parts for many years.
Some of those choke caps are designed for 15 volts ... for exactly that reason. A Ford (Motorcraft) choke cap fits right on a Holley carb, BTW.
Holley's instruction sheet advises AGAINST using the 12V coil feed wire.
I have read in someone's reply here that they think that the power draw of a choke cap is negligible, and I disagree with that. ANY device that is designed to produce heat typically draws a pretty substantial current. If we are talking about the draw required by a RELAY ... OK
  #35 (permalink)
Old 06-03-2008, 11:07 PM
mustang lover
I am also trying to hook up my electric choke in a 1968 ford 302 mustang with a 570 cfm carburetor where should i spice it IN ?
  #36 (permalink)
Old 06-04-2008, 05:13 AM
You might want to start another thread as this one is for a CHEVY
  #37 (permalink)
Old 07-19-2008, 11:59 PM
Last journal entry: not a big fan of cherry picker...
I have a quick question about all this... I read in another post to mount an electrical pump as close to the tank as possible and as low as possible... So in using the oil pressure sensor you should run a wire all the way back there? Seems odd to me... but I am learning EVERYDAY from this site. Along that question where is the best place to mount the pump... say on a 78 Monte Carlo?
  #38 (permalink)
Old 07-20-2008, 02:46 PM
If you wanted to use an oil pressure switch to trigger a fuel pump, you wouldn't want to actually trigger the fuel pump itself but a relay that would power up the fuel pump. and yes you would have to run wire all the way back there. I personally would not even bother to put an electrical pump on and put it next to the engine far away from the fuel source. Because they are made for pushing fuel not siphoning it.
  #39 (permalink)
Old 07-21-2008, 04:13 AM
malc's Avatar
Living At The Speed Of Life
The relay for the fuel pump can be in the engine bay, the pressure switch connects to 86 on the relay 87 goes to the pump, 85 to ground and 30 to battery positive.
The pressure switch is in turn connected to the start circuit and ignition switched 12 volts.
Only one wire has to go back to the fuel pump from the relay, connection 87.
  #40 (permalink)
Old 07-21-2008, 04:16 AM
malc's Avatar
OldUsedParts has his pump mounted on the inside front fender of his 55 Chevy and it works just fine.
Instructions usually call for them to be mounted near and below the fuel tank.
  #41 (permalink)
Old 07-22-2008, 01:07 AM
Instructions usually call for them to be mounted near and below the fuel tank.[/QUOTE]
They must not stand on the gas much/make a full run with it through the gears WOT
How does an electric choke work? firewood Engine 18 06-19-2010 07:19 PM
Quadrajet electric choke. kegross1 Electrical 7 09-21-2009 08:01 AM
Manual or Electric Choke? 58Chev Engine 6 06-02-2006 07:00 AM
Electric Choke Conversion ? bigjoedo Engine 2 01-27-2003 07:17 PM
Carburetors, electric or manual choke? 66StangBoy Engine 5 11-07-2002 04:30 PM
