A question for you electric choke guys - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2008, 08:33 PM
What is the easiest 12 volt ignition source to use for wiring up my choke? I know it can't be connected straight to 12 volts all the time I just don't know which wire to splice off for my choke. Any input here appreciated.
Thanks,
Keith
Old 05-29-2008, 08:37 PM
probably the coil. without knowing your car, hard to say
Old 05-29-2008, 08:40 PM
Last wiki edit: Wiring diagram 1953 Chevrolet
Last journal entry: Spare Tire Dent Removal
Wiki Edits: 647
What kind of vehicle?
Old 05-29-2008, 08:50 PM
its a 1980 camaro z28
Old 05-29-2008, 09:43 PM
Greg T's Avatar
www.krusinklassics.net
DO NOT tap into the coil or distributor lead. Run a separate wire from a switched source at the fuse block.
Old 05-29-2008, 10:00 PM
I would wire it into an oil pressure switch... Then you do not have to remember to turn it on or off...
Old 05-29-2008, 10:21 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I would run it to the IGN side of the starter(not the STR side) with a fused wire. This is a "run position source" that will not effect your engine performance, or breach your firewall to get power with the key on.
Old 05-30-2008, 12:17 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I split off the HEI pink wire. Everyone says not to do it, but its a very low-draw item. Its not stealing any juice from the HEI since the 12-gauge supply wire is more than adequate for both.
Hooking to the starter will only give you voltage during cranking. There are no switched ign leads on any common starter I know of. Just hot and start.
The oil pressure switch is a good idea. I've done that in a few cars that didn't have "acc" positions on the key. If you spend a lot of time in your car with the engine not running but the key in the ON position, this might be a wise investment. An added benefit is that you can also wire your HEI through that switch, so that if you lose oil pressure the engine shuts off.
Old 05-30-2008, 12:25 AM
techinspector1's Avatar
Wiki Edits: 326
Never have done it, but someone mentioned running it off the windshield wiper motor hot line.
Old 05-30-2008, 05:42 AM
I'd like to see this spot never seen a run position on a starter ever.
I know of 3 positions on a gm starter of that era. and they are big post= hot all the time directly from batt+...then (R) which would be used for a points setup
this sends 12vdc to the coil during cranking only. Then the (S) terminal which is for cranking 12vdc from ignition switch to trigger the starter solenoid.
The reason i mentioned oil pressure switch is thats how the factory did it. They either used a 3 prong oil sender at the back of engine behind of distributor or a 2 prong sender just above the oil filter boss on small blocks.
Old 05-30-2008, 08:02 AM
Jmark's Avatar
Wow, lots of ideas on this one.
I too have never seen a "run" terminal on any starter.
I HAVE hooked the elect choke to the HEI "batt" lead and it's been working fine on my truck for like that for over 16 years now. I also wired in my idle solonoid to the same wire, still working fine.
On my 86 truck, I added a charging solonoid to run dual batteries. I needed a "trigger" source for it and ran it to my wiper motor. One wire is hot when the key is on. Yep, working fine too.
As far as wiring it to the oil sending unit???? How does that work? The stock sending unit is a one wire unit that sends a ground signal to the guage, atleast on my three Chevies. I don't see an easy way to isolate the electric choke ground so you could accomplish this. Can someone 'splain it to me? LOL
Bottom line, the elect choke amp draw is minimal and can be hooked to just about anything handy under the hood.
Mark
Old 05-30-2008, 08:52 AM
Simple answer, tap in to any 12V source that is hot when the key is in the "on" position. I used the power wire for the windshield wiper motor. It is close and readily available.
Old 05-30-2008, 01:35 PM
malc's Avatar
Living At The Speed Of Life
My 1978 Camaro had a Q-Jet with electric choke,
how did yours lose the hookup ?
Old 05-30-2008, 04:57 PM
Mark
Depends on the oil sender used some used a 2 prong which would be just for the choke itself and most were mounted above the oil filter boss. some vehicles used a 3prong oil sender back by the distributor one of the wires would have been for the oil gauge and one 12vdc and the 3rd wire to the choke
Old 05-30-2008, 07:58 PM
T-bucket23's Avatar
Wiki Edits: 26
The type and quality of the connection and proper wire sizing is more important than where you physically connect it. Be sure is is fused as close to the source as possible. Running by the mainfold has big potential for a broken or pinched wire.
PS There is no terminal on a Chevy starter that is switched on with just the key on.
How does an electric choke work? firewood Engine 18 06-19-2010 07:19 PM
Quadrajet electric choke. kegross1 Electrical 7 09-21-2009 08:01 AM
Manual or Electric Choke? 58Chev Engine 6 06-02-2006 07:00 AM
Electric Choke Conversion ? bigjoedo Engine 2 01-27-2003 07:17 PM
Carburetors, electric or manual choke? 66StangBoy Engine 5 11-07-2002 04:30 PM
