I pretty much tried about every way there is to strip paint of cars.Those little discs are pretty good for irregular surfaces like jambs,fender lips, louvers etc...What I really like is they dont leave grinding marks and really polish the metal nice (ready to prime)unless there is a LOT of paint then they are slow and expensive.I found that the fastest and most economical way to strip a car is with aircraft stripper from Kleen-Strip.Once the majority of the paint is off those pads can save some time if you can afford the extra expense.Theres a few tricks to chemical stripping that make it pretty easy,and without any mess,unfortunately you have to learn them from someone or strip quite a few cars to learn most of them.
A good stripper can strip an average 2 dr car ,jambs and all in 8hrs at a cost of 40-50.00 plus a few rolls of tape and paper,without the dusty mess of friction stripping or blasting.
those discs work by softening the paint with heat and those big ones will warp a hood if your not careful.
Try placing your hand on the metal every few minutes ,if its to hot to hold your hand on it its getting too hot.They're better than grinding discs but they're not so good for a newbie to use.
I would strongly recommend you to use the Kleen-strip aircraft stripper for the best results....and save those little discs for the jambs.
BTW,its the edge of the disc that does all the work it wears out quickly and starts slowing down...if you trim off a 1/4 -1,2" and screw it into a smaller backer they'll be useful all the way down to the nub and the smaller they get the tighter the spot they can be used in....Heres a pic I had on hand to help you understand how I use them....these are rol-loc grinding discs but its the same idea and works well for both to get the most out of them. it's also a big time saver to have a few (el cheapo) dedicated angle grinders from Harbor frieght for each pad so you dont have to stop and re-chuck different ones..I use an old pair of tin snips to cut them....
Those big metal conditioner pads were pretty expensive when they first came out I wonder what they cost these days....
