Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2008, 03:44 PM
Questions
hey all couple questions here
1. how much does it cost to lift a truck (per inch)
2. how much does it cost roughly to put dual exhaust on a truck
3. how much does an average set of wheels and off road tires cost
this all doesnt have to be exact just an estimate..thanks a lot guys
Old 05-11-2008, 05:49 PM
Holder350's Avatar
Auto Parts Professional
ok theres no set per inch cost for lifting.....really depends on the vehicle. 6" kits for the new wranglers are about 3 grand while a 4" kit is only 1
duel exhaust will cost about $200 (last one I had done.)
Wheels also depends on what you get. Anything from a $40ech black steel wheel to a $200ech Aluminum wheel (average) to a $300ech set of customs.
Tires are depending on size. Super swampers are my fave because they are cheap and great in mud. Range from 120-170 a wheel.
Old 05-11-2008, 06:04 PM
poncho62's Avatar
Wiki Edits: 5
In this hobby, if you have to ask, you probably can't afford it...........
You can do as I always have, and do the work yourself.....Labour is a big chunk of the cost of most mods.
Old 05-11-2008, 06:16 PM
Holder350's Avatar
Ditto Ponch
Some of us even make our own parts and tools......just make a steering colum lock plate compressor today.
I find that I rather do my own work just because then if something breaks I know where and what to do to fix it.
Old 05-11-2008, 08:35 PM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
www.fourwheelparts.com
www.summitracing.com
www.jegs.com
For fabricating dual exhaust go ask an exhaust shop what it will cost.
Two questions about a BBC RObs71Nova Engine 10 07-03-2012 02:55 PM
1940 Ford pickup box and door questions? Skiman Hotrodding Basics 10 04-04-2011 05:50 PM
Suspension-Brakes-Steering Common Questions Jon Suspension - Brakes - Steering 0 10-16-2003 03:19 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 02:01 PM
Nuts, Bolts and stripping questions Bluepen Body - Exterior 5 08-14-2003 05:15 PM
