Questions on '37 Buick ignition - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2011, 01:52 PM
Mutt's37Buick's Avatar
I found some keys that appear to work in the ignition of my 37 Buick, but I do have a couple of questions that perhaps someone could help with.
The ignition is probably the original 37 ignition.
1) There is a small metal lever on the right side of the ignition that can be flipped up or down. Do you know what that lever is for?
2) The key turns counter-clockwise which is opposite of what I'm used to. Does that make sense?
Thanks
Old 11-30-2011, 10:35 PM
switch
The lever is probably your on/off switch and a button on dash turns starter. Key is to lock switch so it can't be moved. Not sure but it may also lock your steering column.
Old 12-01-2011, 10:26 AM
Thanks for your help
Msd Ignition questions old fords Electrical 5 08-14-2008 12:25 PM
Ignition Moduale Questions wayfast77 Engine 2 04-14-2006 12:52 PM
Ignition Timing On 350 4 Barrel Buick alrobjr General Rodding Tech 2 01-30-2006 07:31 AM
pontiac ignition questions 67bird Engine 6 01-14-2004 11:43 PM
Chevy Ignition questions Camaro2Fast4u Engine 1 03-05-2003 01:36 PM
