Questions about 4-link suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-22-2006, 10:40 AM
Last journal entry: The Nash
I'm going to install 4-link in my 28 Nash coupe, but have a few questions. How long should the bars be, how far apart ( top and bottom bars ), size of tube to use, mounting location on the diff, and what would be the best, and cheapest type of bushings to use. Also I am planning to use a leaf spring sideways to save as much space as possible, and to get it really low. Is this a good idea or not. Also would i need a sway bar for this aplication?
Old 01-22-2006, 10:54 AM
As the moderator here, I would like to WELCOME YOU here...
If you are going to run a leaf spring across the rear...you only need two lower bars to help keep the rear end in position. This was/is a common practice in early V8 Ford hot rods. The longer, the better the ride ( to a point ) . I suggest you look at a stock 35 to 40 Ford rear suspension....for ideas.
Again....WELCOME
Deuce
Project Journal link not showing up 78novaman Hotrodders Site Suggestions and Help 11 07-23-2005 10:06 AM
Rack & Pinion Steering on a Chevy C-20 Suspension? Dusty82 Suspension - Brakes - Steering 3 03-01-2005 10:15 AM
Drag Suspension Questions HoosierDaddy Suspension - Brakes - Steering 12 02-26-2004 04:15 AM
Suspension from scratch? fairlaniac390 Suspension - Brakes - Steering 5 02-22-2004 09:26 PM
69 camero suspension questions 69camero559 Suspension - Brakes - Steering 4 02-14-2004 12:38 AM
