questions about 4l60e - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2005, 10:35 PM
this is my first post on this forum but i read it every weekend @ work and have used ALOT of your advise in the past few months on my current project.
i am in the process of replacing my little brothers 4l60e in his 1996 4.3l 4x4 chevy. my question is regarding the output shaft of the 4l60e.
is there a difference in the 4x4 output shaft and the 2 wheel drive output shaft on the 4l60e. i have been told conflicting information and my search has lead me to a dead end.
his tranny is the 2 piece bell housing design. i have been shopping for a few days now and have found several good deals on 2 wheel drive tranny's. i called a reliable source here in OKC that i buy from regularly (ariel automotive) and he said it was the same, but a rebuilder told me they were different. ( since i am footing the bill for this i would like to get out of this fairly cheap. )
thx for the help Aaron
Old 04-10-2005, 12:28 AM
Crosley's Avatar
Wiki Edits: 1659
the 4x4 shaft is shorter than the 2WD shaft in a 4L60E.
You cannot cut a 2WD shaft down to the length of a 4x4 shaft on the 4L60E.
by this statement... the bell housing unbolts from the main tranny case?
Old 04-10-2005, 12:36 AM
yes the bell housing unbolts from the main tranny case
that answers my question thx crosley.. i guess its off to get this one rebuilt. thx again
just out of curiosity why couldnt one cut down the shaft?? it looks to be just a few inchs longer.
Old 04-10-2005, 08:27 AM
Crosley's Avatar
Wiki Edits: 1659
If possible I would suggest that look at both the 2WD & the 4x4 output shafts side by side.......
2005 4L60E tranny Crosley Transmission - Rearend 8 05-18-2008 01:51 PM
Interior -- Common Questions Jon Interior 0 02-12-2004 04:38 PM
Suspension-Brakes-Steering Common Questions Jon Suspension - Brakes - Steering 0 10-16-2003 03:19 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 02:01 PM
Nuts, Bolts and stripping questions Bluepen Body - Exterior 5 08-14-2003 05:15 PM
