Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - questions about alcohol engines
Old 05-09-2005, 07:26 PM
nova63and66's Avatar
nova63and66 nova63and66 is offline
New Member
I've got a few questions about running alcohol in an engine. The engine is all setup for alcohol and was wondering if you have to use special motor oil and when breaking the engine in and when getting it hot enough to let all the seals set up should you run gasoline so the engine can warm up enough so that the seals seal up properly.
