Questions About Big Block Chevys - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2010, 11:34 PM
Would the piston hit the valve or the head while the motor is running with a 10.2 inch deck height a 4 inch stroke and a six. 13 five inch rod and flat top piston the cam has 292 advance duration on exhaust and intake with five fifty lift on the cam
Old 05-04-2010, 12:56 AM
for a tall deck just get standard pistons with a 6.535 rod.
Old 05-04-2010, 04:56 AM
BOBCRMAN@aol.com's Avatar
Not only will your pistons not hit the head. They will not even come to the top of the cylinder. With a 6.135 rod you will be .400 down in the bore. No compression.
Old 05-04-2010, 08:55 PM
I wanted to go with the bigger rod but i was worried about the piston hitting the head and i forgot to say that im gonna run a 871 blower with this motor thats the reason for the flat top pistons
Big Block Exhaust Question RamAirZ Engine 2 07-22-2009 05:03 PM
Big block questions, help please??? 67 sleeper Engine 20 05-15-2007 05:24 PM
427 Big block blew up, need a few suggestions. esears Engine 17 03-12-2007 09:18 AM
need info on small block chevys engine-rookie Engine 1 05-03-2003 09:48 PM
Big Block/Small Block - Ford BigBlockBabe Engine 12 11-10-2002 05:01 PM
