Questions about my dual carb set-up - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2011, 08:06 PM
Z-Money Pit's Avatar
I am in the process of installing a dual carb set-up on my Chevy 261 Inline 6. I have a pair of Carter-Weber 2 barrel carbs that are getting mounted to an Offy intake. The Carter-Weber's have an electric choke. Do both of these get wired or just one, leaving the other with no choke?
Also, what gauge wire would you use for the electric choke. I am still running the original 6 volt system on this old Chevy.
Thanks,
Chris
Old 06-14-2011, 08:54 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I would only use one choke. It should be sufficient.
12 gauge wire will do the trick. Are you sure the chokes are 6v? If they're 12v chokes and you only give them 6 they'll never open.
454 tbi or dual tbi on dual 4bbl carb intake 90GMCVortec Engine 3 10-28-2008 02:48 AM
dual carb 86regal Hotrodding Basics 3 03-11-2008 07:34 PM
Dual Carb Lord_Hate Engine 8 08-27-2007 09:01 PM
dual carb setup for BBC BlackRat Engine 7 01-21-2005 07:13 PM
dual carb manifold leftoverchrisac Engine 3 12-26-2003 10:07 PM
