questions about swapping R/E gears from a 12 bolt Gm into a Pontiac 10 bolt housing l - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2007, 10:53 PM
Bad Rat's Avatar
Last journal entry: Bad Rats anglia Build Journal plus bike and other photos
Wiki Edits: 2
I have a 69 pontiac bonneville that has a 10 bolt rearend,, probably a 28 spline,// with 3.08 gears,, and also I have a 12 bolt[ 1977] out of a surburban, with a 3.72 posi , probably a 31 spline?? they are the same width, so what I am wondering is,, would it be possable to change over the posi and axles into the pontiac 10 bolt housing?? I could probably change the whole rear end , but the spring locations are in different locations,, so it would involve some fab work to make it work,, the pontiac is a 8.2" and the 12 Bolt is a 8.7/8,,,[,I Think] any one have any suggestions : confused:
Thanks Bill
Old 06-11-2007, 07:54 AM
Last journal entry: car is painted
None of the internals will interchange.
Old 06-11-2007, 08:34 AM
Bad Rat's Avatar
Wiki Edits: 2
Thanks,, MIKE,, it was just a bad brain fart that went astray,,,,
Old 06-11-2007, 08:35 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Hi Bill,
I know the fellow is right..You are up for some fab work to change those rear ends..Maybe get Billy over there and help you out a bit..
Sam
Old 06-11-2007, 08:39 AM
Bad Rat's Avatar
Wiki Edits: 2
Hi Sam,, hows things with you,,?? stayin dry?? Billy joined the carpenters union and is working at the new provendance hospital here,, went to work with my oldest son,, doing well,, [about time ] Thanks for the reply Bill
Old 06-11-2007, 10:12 AM
Wiki Edits: 3
Trying..Kinda cool in the shop with no heat..trying to paint a fire truck rig these days..Where is the sun?
This thread has been throughly Hi-jacked...
Sam
Old 06-11-2007, 10:50 AM
The sun is down here in CA.
Exploded spider gears...? (12 bolt GM) Bumpstick Transmission - Rearend 7 10-07-2003 06:00 PM
8.5 GM 10 BOLT CARRIER SWAP, POSSIBLE?? PURPLEOMEGA Transmission - Rearend 0 09-18-2002 03:04 AM
Swapping a 10 for a 12 HotRodS10 Transmission - Rearend 3 06-26-2002 07:03 PM
