Questions about wiring a custom aluminum fuel cell - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-01-2008, 03:43 PM
Wiring a fuel cell is new to me.
Custom aluminum cell. 2 fuel pumps, Y'd into a single outlet. Each pump has its own power leads/feeds.
First, looking for recommedations on plates/connectors for the top of the cell, for the electrical lines. Maybe something that will accept some sort of weather pack like connector?
Second, what is the proper wire splicing method for the lines in the cell? The leads on both pumps are too short, so I am going to have to add some wire to get to the top of the tank. How to do so? Solder the extensions on, then use heat shrink on the wires? I would think the heat shrink will succumb to the fuel and deteriorate.
Thanks,
Jeff
Old 11-01-2008, 06:57 PM
If you use the heat shrink, use the stuff with the hotmelt glue lining. When it shrinks the glue melts and forms a total seal to the wire's insulation. I do not know what gas will do to the heatshrink. TF
Jet Boat Fuel Pump Question(s) ezobens Engine 22 09-02-2009 10:52 AM
!!!!! HELP - CARBURETOR LEAKING & FUEL TANK NEEDS TO BE CLEANED!!!!!!!!!!!!!!!!!!!!! islandman Engine 3 03-17-2007 04:36 PM
Rci Fuel Cell? tombo615 Hotrodding Basics 3 12-05-2006 09:42 PM
fuel cell set up??? fireforsin Engine 3 08-13-2004 08:53 AM
Bonding Custom Aluminum Panels To Steel bmech211 Body - Exterior 2 12-16-2003 09:49 PM
