Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - questions on building a small block chevy
Old 11-20-2003, 02:32 PM
Pianoman Pianoman is offline
Decadent pianoplayer
Re: questions on building a small block chevy
Originally posted by ATMRacerTX
I have about 1500 and i am wanting to build a small block chevy my questions are what should I look for in buying a block, heads, intake..etc and what mods should i do to get the most out of this enginefor the money?
Well, if I were you Iīd do it like this:
1) Lift the heads and look at the cylinders at least. Or tear the whole engine apart and check it out.
2) Donīt just spend money on hp. Make sure you start spending it on making things last.
3) If youīre going for high rpm's, balance it. It will be worth it.
4) Now you can start thinking on getting high comp pistons, kick-a** heads, roller cam etc etc.
The only problem is that doing it like this cost money. Much money. On the other hand you donīt have to make repairs as often.
Last but not least, do what you do now: Ask. And remeber no answer is an absolute truth (neither is this).
