questions for everybody - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2005, 08:26 AM
spinn's Avatar
good morning. i was wondering, basically what setups people are running? how "HOT" are your rods? maybe state its purpose. this can help people decide what setup to go with.
what do you idle at?how much vac?
what cu" ?
what comp. ratio ?
what cam ?
what gears ?
my car-is a sunny day cruiser with a dark side. 2700rpm@65mph
850 rpm with 11" , SD 750VS
440
9.43:1
hughes cam .524/.540 lift
3.23
Old 03-20-2005, 08:42 AM
Lonestar's Avatar
"May the Schwartz be with you"
Last journal entry: Finally getting going...
1500 rpm
6.5"
327 + .030
12.73:1
custom
depends on the day, anywheres from 3.42 - 4.56
Old 03-20-2005, 10:06 AM
tornado-tech's Avatar
900 rpm 14.5 in vacuum
400 + .040
11.1
Comp 282/288 .510/.520 hydraulic roller
4.11:1
Used strictly for mud bogs and mud drags
Old 03-20-2005, 10:47 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
New motor, completed but still on the stand.
383 SBC
8-71 w/2 BG 750's
8-3:1
Dart Pro-1's
Lunati solid roller .535 (w/1.7's) 282/290 Isky Red Zone lifters
4:11 FAB-9"
T-400
Built for the street may run 1/4 fun only. Pictures in my gallery.
Old 03-20-2005, 10:56 AM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
why
454
800 rpm, set idle jets by rpm
9.8 to 1
.544 crane
4.71 gears
Old 03-20-2005, 11:09 AM
MI2600's Avatar
Member# 3287
My rod is not so hot...it runs about 190 degrees.
how does this sound (primer/filler questions) Dubz Body - Exterior 13 08-29-2004 08:58 PM
Interior -- Common Questions Jon Interior 0 02-12-2004 04:38 PM
Suspension-Brakes-Steering Common Questions Jon Suspension - Brakes - Steering 0 10-16-2003 03:19 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 02:01 PM
Nuts, Bolts and stripping questions Bluepen Body - Exterior 5 08-14-2003 05:15 PM
