questions on HF blast cabinet - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-20-2004, 03:23 PM
I am looking at a blast cabniet from Harbour Freight on sale for $199 but have a couple of questions.Can you re-use the sand or do you have to replace it ever so often?Is my IR sinsle stage 5HP 60 gallon air compressor enough?
Old 05-21-2004, 02:13 AM
New Member
Use the sand until it stops cutting well, then replace it. Personally, I use Aluminum Oxide in my HF sandblaster, not real expensive and does a great job. It's the same one you're looking at. That compressor should work, although you may have to take breaks once in a while while it repressurizes your tank. What is the CFM rating on your compressor @ 90 PSI? They are pretty decent units overall. I know people think it's cool to bash HF stuff, but that cabinet is a pretty good deal. I've got a lot of use out of mine.
Hope this info helps you out.
Ron
Old 05-21-2004, 02:30 PM
New Member
My father-in-law has a HF cabinet he has used for years, and has done fine. His problem is he has a hole in one of the gloves and HF doesn't have replacements. Anybody know where he can get them?
Old 05-21-2004, 02:36 PM
Tim240Z's Avatar
Duct tape!!
Old 05-21-2004, 03:12 PM
New Member
Try TP tools. Here's some blast cabinet gloves they have:
TP Tools
Ron
Old 05-21-2004, 03:16 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Harbor Freight
or
Gibson
or
Northern
