Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Questions for the hydraulic T/O brg pros....
Old 01-25-2013, 02:47 PM
31ROC's Avatar
31ROC 31ROC is offline
This is my first hydraulic T/O brg install.....seems to have a LOT of instructions, measuring block to crank, bell to this & that, pressure plate to that....etc...which I think I understand.... but the sheet of instructions does not show where shims go? Are they behind the brg against the face of the tranny? Instructions indicate a tolerance of .150-.020 for play clearance...and it doesnt show WHERE this clearance is located? anyone else install one of these? It is a RAM clutch set, and RAM hyd. brg. Chevy 350, Muncie 4 speed....the brg cam with only 1 flex hyd line? but there are two fittings for feed, and for bleed...why onky 1 line supplied?
Lastly, do I need to have the clutch master and pedal all hookked up in order to install this brg and clutch assembly?
thanks as always!
