Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Questions for the hydraulic T/O brg pros....
Old 01-26-2013, 05:48 AM
31ROC's Avatar
31ROC 31ROC is offline
LATECH...great information and thanks!
I have one last question---when you say go ahead and "mock up" the clutch and "set up the brg clearance", not sure what you mean?
Install pressure plate and disc onto flywheel? do you want this assembly on them motor? if so, if I slide the brg onto the tranny I would have to install the bell and install the tranny onto the bell, how would I get to the clearance gap in order to measure?
OR..........do I slide brg onto tranny, then slide clutch PP & disc onto tranny then measure?
signed:
rookie
