So, I figure out shims go behind the brg..(DUH),and I am in the opposite direction for needing shims.... but no matter how I try following the RAM instructions, I cant come up with the recommended .015-.020 clearance between the brg face and pressure plate fingers. UNLESS I shim the bellhousing away from the tranny a bit....anyone ever done this?
maybe because I have a lakewood bell instead od stock bell? Maybe its that much shorter enough tom throw it off?
