Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Questions for the hydraulic T/O brg pros....
Old 01-27-2013, 03:14 PM
31ROC's Avatar
31ROC 31ROC is offline
OK...so embarassment has set in.........
Got up today, to start all over with this flipping hyd T/O brg, only to read the instructions for the 47th time.....guess it takes 47 times to realize, its not a tolerance of .015-.020 for clearance, ITS .150--.200 !!!!
That being said, the shim for the tranny to bell has increased significantly!
But took your advice, went to Lowes and picked up some aluminum flat stock and made two "tranny width" shims....installed, re-measured (48th time), and waalaa, I am now at .177---right in the middle of said tolerance!
I guess repeated usage of Dewars White Label may cause failure to read instructions correctly....
