What do you have lying around the yard? Can you fit a small child in the hole? (they can hold a cover over the hole!
) If you have some tin from an old fender, hood, etc... or even an old stove or washing machine (but you need to rough up the surface a bit to get your bondo to "stick" better) you could always weld or rivet that in place before using the filler. If this is for a quick "clean up to sell" kind of job, screen from a screen door would work for a week or two. Ideally, replace the fender - otherwise be creative! Best of luck! ~Joe |
The correct way is to cut a patch panel for it, weld it in place, grind it smooth, skim coat it with bondo, sand it smooth, and paint it. Hope that helps.
a "goob" of bondo is too ridgid, it will crack around the edge in no time from hitting pot holes and rr tracks driving
if you were my son,(he's 16 yrs old) I would tell you to find a auto paint supplies store (or possibly a local body shop?) that will "loan you" a "2 part panel adhesive" gun ($100? to buy one) and have you buy a tube of the 2 part panel adhesive ($40?) grind the hole bigger till there is no rust, only bright steel.... cut a piece of good scrap roughly1- 2" bigger than the hole to make a patch.... bend that piece till it conforms exact to the inside of the fender.... cover the whole surface of the patch with enough adhesive that it oozes thru the hole, once it is cured, sand the extra off the front, may/probably will need a thin coat of bondo on the front to get it perfect it's fixed for the next 20 years |
| a few body work questions | tcoop | Body - Exterior | 1 | 01-21-2007 10:38 AM |
| body work | mytyty | Body - Exterior | 1 | 05-16-2004 09:28 PM |
| Will this work? Chevy 305 Throttle Body w/ Chevy 350 | aberg12012 | Engine | 9 | 05-07-2004 12:28 AM |
| Body panel work stand? | gsrokmix | Body - Exterior | 3 | 02-21-2004 05:14 AM |
| Mustang Body Work | Stangman196700 | Body - Exterior | 16 | 02-20-2004 04:12 PM |
