Questions on TV cable and converter lockup on 700r4 - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2011, 08:07 PM
I've just read TVmadeEZ add. I'm Replacing a t350 with a t700r4. Is this kit necessary and is replacing the spring needed without the kit? Johns cars sent me two switches one vacuum and one pressure to lock up the TC, and a blue and brown speedometer gears. this 700 has an electric speedo. I'm totally confused. Please help?
Old 06-10-2011, 08:38 PM
SSedan64's Avatar
It's a nice kit but, not neccesary. Normally, you only need to replace the TV spring when using BTO's TVMadeEZ kit.
The Vacuum switch prevents Lockup when vacuum is low & allows Lockup when vacuum is high/higher.
The Pressure switch goes in the 4th gear Pr. Port on the Valvebody, it sense 4th Pr. & supplys -Ground to complete the circuit.
http://www.hughesperformance.com/pdfs/HP700-R4.pdf
You will need the correct Throttle & TV cable bracket + TV Geometry corrector Bracket.
""What type Carb are you using""?
Old 06-11-2011, 10:09 AM
reply
Quadrajet, I planned (hoped) to be able to use the 350 kick down cable bracket.
Old 06-12-2011, 07:07 AM
SSedan64's Avatar
May be able to Mod the Detent cable bracket for TV cable use.
The Q-Jet's shaft for Detent cable & TV/ThrottleValve cable have 2 different Throttle linkage position mounting points. This throws off the TV cables geometry & will need to be swapped or modded.
Info & Pics>> http://www.montecarloss.com/communit...192#Post825192
BTO 'may' have an TV adapter kit for this.
Old 06-12-2011, 04:09 PM
Bto?
OK but who or what is BTO ? This still doesn't answer if I need the blue and brown gears with an electronic speedometer and if it will hook up directly to my 85 JAG XJS's speedometer ?
Old 06-12-2011, 05:47 PM
SSedan64's Avatar
BTO = BowTieOverdrives
http://www.tvmadeez.com/article/index.php
http://www.bowtieoverdrives.com/catalog/
The 'Jags That Run' site should have the Speedo Info.
http://www.google.com/search?hl=en&s...&aql=f&oq=Jags
Old 06-13-2011, 07:56 PM
Da
BTO? Have you ever felt like you just got bitten by the D***A** BUG, I do.
Thanks for all the help, now all I have to do is dig through all this info. The only thing wrong with the net is TMI, TMI. This was supposed to be a simple switch right!!!
700r4 , lockup converter electrical questions patmckinneyracing Transmission - Rearend 1 06-25-2010 09:47 PM
700r4 Torque converter lockup coming on and off chevy_c10 Transmission - Rearend 4 05-04-2010 08:43 PM
700r4 lockup converter questions 71/454 Transmission - Rearend 2 01-17-2010 09:36 PM
700R4 lockup converter help needed Augusto Transmission - Rearend 2 01-21-2008 03:24 PM
Converter lockup questions 87442lover Transmission - Rearend 3 08-28-2004 12:28 AM
