Questions on V8 s-10 suspension for V-8 beetle
Hello everyone, as some of you guys know I’m building a V8 powered 69 convertible bug on an S-10 chassis.
![]() Being that the chassis has 212,000 miles on it I’m planning on basically rebuilding the front suspension, and may do a few upgrades along the way. I just had a few questions and hoped I could get a little help. First of all the chassis was from a 92 2wd 2.8L v6 standard cab if that makes any difference. Also I have the 350 mounted about 6" further towards the rear than a normal V8 s10 conversion. Also I’m not planning on racing the car at all, its just going to be a toy for messing around with and cruising. I’d like it to handle pretty good, but at the same time I’d like the ride to be fairly comfortable. (otherwise the wife might complain LOL) Cost is also a bit of an issue, I can’t go dropping tons of cash in the front suspension (mostly because I don’t have it LOL) but if I have to I’ll wait and save rather than throwing crap on it. First off I figured I’d replace the springs being that they have over 200,000 miles on them. Being that I now have a 350 sitting up front instead of the 2.8L should I upgrade to stiffer springs, or will stock springs work just fine???? I just don’t want the front end to be “mushy” because of the extra weight, etc. Also I’m planning on sticking with stock height springs, if I do drop it any I’ll go with some 2” drop spindles so I don’t screw up the geometry at all. I’m just not sure if I’ll need the drop though. How about shocks, anybody have any they love or hate??? Are Stock OEM shocks ok, or would something stiffer be better??????? The main reason for asking about the shocks and springs right now is because someone on the local craigslist has a set of brand new OEM S-10 springs and shocks that I could pick up cheap. Now how about Upper control arms??? I’m thinking of at least putting tubular uppers on to save on room and they’d look nicer. Maybe lowers too if I could find some cheap(er)??? What are you guys using for tubular control arms on the S-10s, anything that’s not too pricy??? Do any/most/some/none of the g-body control arms work or are there others that are interchangeable??? I can’t afford to spend $500 on a set of uppers, are there cheaper ones that would work for my application??? If not I may have to stick with stock. I’ve seen these on ebay and they caught my eye (because I could afford them LOL) Are they any good or just plain old crap??? http://tinyurl.com/ykapod7 and these http://tinyurl.com/yzgp8vy I also I figured I’d upgrade the front sway bar, but that will be easy enough to do later on. Thanks for all the help guys!!!!!!!!!!! |
as light as the body is gonna be i wouldnt go any heavier spring at first. i dont think the springs you have are worn out yet. i would use a heavier shock, i like doetsch shocks, summit racing has them. circle track racing catalogs have them adjustable 40/60 50/50 60/40.
your upper a arms are right here http://www.daymotorsports.com/produc...ER-CONTROL-ARM |
Mine was a 2.8, and I've never had issues with bottoming out. Because of years of racing I have a spring rate tester. We tested my S10 spring years ago, and I'm pretty sure they were around a 325lb spring, no guarantees though that was atleast 5 years ago.
bonuts |
Thanks for the help guys, I also found the control arms at speed way motors and also a couple places on ebay. For now I think I'll just stick with the stock springs I already have in the chassis and if it doesn't seem like I need stiffer springs then I'll get a new set of stock springs if it seems like I need something stiffer I'll upgrade then.
My spare 66 beetle is getting sold on ebay today and I'll have atleast enough money now to get the control arms, and I'll probably pick up all 4 ball joints, wheel bearings and such, and I'll still have enough left over to pick up some steel to start working on getting the body mounted to the frame and work on the floor too. Thanks again! |
| 10 bolt axle questions | ChevelleGuy | Transmission - Rearend | 2 | 06-17-2004 12:08 PM |
| Drag Suspension Questions | HoosierDaddy | Suspension - Brakes - Steering | 12 | 02-26-2004 03:15 AM |
| v8 swap for my s 10 | sooners77 | Engine | 3 | 11-07-2003 04:28 PM |
| 10 bolt rear. several questions | grizzly | Transmission - Rearend | 2 | 04-04-2003 12:37 PM |
| converting GM 10 bolt to rear disc brakes, have questions | HotRodF100 | Suspension - Brakes - Steering | 7 | 09-18-2002 11:22 AM |
