Questions on valve adjustment on a sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-01-2006, 08:29 PM
Hey got a question..I have really only ever adjusted the valves on my sbc with intake manifold off,which made it very easy...my question is is there a good routine or way of performing a valve adjustment on completly assembled running engine with posi lock rollers with hydraulic cam.. my issue is trying to figure out when each cylinder is ready to adjust?? Ive heard of split one and adjust the other in a perticular sequence?? with intake off you can see lifters which made it so much easier!! any tips would be great
Old 06-01-2006, 09:14 PM
kevan
as far as i know what you do to adjust hydraulic valves on a already running engine is ... first take an old valve cover cut enough out of the top to put a wrench in then take good valve cover off put destroyed valve cover on .. start engine then loosen off adjusting nut until valve "clacks" then tighten back until clacking just stops and tighten one quarter turn more ... but don't quote me on the quarter turn could be more depending who you talk to hope this helps
Old 06-01-2006, 09:52 PM
Ya Ive done that on stock valve train..but with roller rockers with posi locks..dosent seem realistic??and I DO NOT want a mess from running engine even with my cut open spare cover..my cam manufacture says 1/2 turn in..
Old 06-01-2006, 10:03 PM
Vortech 4.3's Avatar
jack of all trades
do a search. there is a good thread on this, many replies.
Old 06-01-2006, 10:07 PM
jack of all trades
here ya go
Valve Lash adjustment
Need help with older sbc valve covers 69C10 Engine 4 04-13-2005 10:33 AM
GM fast burn heads batman09 Engine 1 10-26-2004 10:32 AM
Valve lash changing, sbc! al37ford Engine 12 09-21-2004 11:16 AM
SBC short water pump vs long water pump and other questions Jag Daddy Engine 9 04-02-2004 10:29 AM
Valve adjustment T-Bucket Engine 5 05-22-2002 10:04 PM
