a quick 4x4 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2006, 06:44 PM
jesse01's Avatar
mini me
what is this http://cgi.ebay.com/ebaymotors/ws/eB...B:EOIBSA:MT:42
i have a 203 transfer case, but still knida wet behind the ears when it comes to 4x4. so what exactly does this do? how does it work? and how does it mount up?
thanx again, J
Old 04-10-2006, 10:13 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
I'm not big on th 4 x 4 stuff either Jessie
but from what i can tell its #2 of a dual transfer case set up
to doubly lower the gear ratios to do some serious slow off roading
like floor it & come back 10 minuets later after taking a dump & grabbing a beer
but while pulling a house
have you tried
www.pirate4x4.com ?
R
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 04-11-2006, 01:38 AM
M&M CUSTOM's Avatar
Wiki Edits: 9
The seller gives a link to explain this further.
http://www.offroaddesign.com/catalog/doubler.htm
This will mount using an NP-205 transfer case, BUT this will allow you the added option of dropping down another 2 to 1 gear ratio, thus the name doubler.
This part of the NP-203 transfer case has no chain, so it is just as strong as the 205.
I have at least a half dozen of these laying around. Cheap and easy to come by.
Old 04-11-2006, 04:32 PM
jesse01's Avatar
mini me
Rob, no i havn't tried that place but thanx for the link
M&M, sorry i didn't even see the link there. i must of glanced right over it.....oops
how hard would it be to mount? would i have to change my driveshafts or anything?
J
Old 04-11-2006, 04:48 PM
jesse01's Avatar
mini me
never mind i found my answer in that link i missed
thanx, J
Quick oil pressure question. oldschoolrods Engine 8 05-11-2005 08:51 PM
Quick Application Question. MontegoMX Body - Exterior 4 03-14-2005 03:15 PM
Yes, a quick stroker question joeyg329 Engine 2 06-30-2004 07:29 AM
quick nascar question 67bird General Rodding Tech 4 05-24-2004 08:54 PM
Quick question on timing an engine? ATMRacerTX Engine 8 12-17-2003 01:00 PM
