Quick ? about mounting hood scoop - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2009, 04:48 PM
My malibu had a cowl scoop mounted by the previous owner and it is cracking where it was bondoed to the hood ((it was screwed to the hood) I tried grinding the crack out and using filler, sanding down smooth to repair.But it looks good when I'm done but when back to the garage a few days later the crack re-appears. What should I use to repair this duraglass? fiberglass? I'm not a body guy but with the money I am putting in it with the base clear paint I will be using I want to fix it right.Any help apreciated
Old 01-27-2009, 06:16 AM
Thanks, knew I shoulda hit search first.
1951 chevy hood ? Area_51 Body - Exterior 6 02-15-2008 04:21 PM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 09:24 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 09:20 AM
Hood scoop problems 79Camaro74Vega Body - Exterior 8 02-01-2004 08:45 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
