This diaphragm is to seal the fluid from the air to keep from contaminating your brake fluid with moisture. As the fluid level changes when you apply the brakes the diaphragm moves with the fluid level. As the front brakes (on front only discs) wear, the fluid level drops as the piston moves out of the bore. The large chamber of the M/C runs the front brakes in a disc system so it would be normal for it to be pulled down and the other not. If it is the other way around I would look for a leak in the diaphram. In reality, unless you keep the M/C full to the top both will be pulled down some.
No, there is still dirt and water to consider, especially in an underfloor arrangement. while the moisture is not absorbed into the silicone fluid, it can still destroy your system by corroding components internally if it gets into the system. Dirt in the system will wear it out at an accelerated rate. In short, do everything possible to keep your system clean and dry. I have never had an underfloor but if I did I would consider some sort of boot to cover the M/C.
| HELP...'85 Seville brake question | Kevin45 | Suspension - Brakes - Steering | 0 | 09-21-2004 02:27 AM |
| Quick carb question | 357ford | Engine | 4 | 09-01-2004 08:55 AM |
| 69 firebird brake question | fletch69 | Suspension - Brakes - Steering | 5 | 08-03-2003 12:35 PM |
| Members from the UK quick question | 78 monte | Hotrodders' Lounge | 3 | 02-23-2003 03:35 PM |
| Quick 77 Camaro Roll Cage Question | izzymiddleton | Hotrodders' Lounge | 0 | 01-10-2003 09:35 PM |
