quick carb question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2008, 07:37 AM
hddave1's Avatar
quick carb question
(edelbrock 1406) if the float is out of adjustment will that cause the plugs to read a rich condition and the smell of gas..
Old 03-17-2008, 10:04 AM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Yes, and they are known to be adjusted too high when new. plus their specs are too high, IMO
Get specs from a 60's muscle car AFB instead.
I just found another problem on one last week; one of the metal floats was 1/2 full of gas! There is a spot of solder where they had a bleed hole that is used when soldering the 2 halves together. That bleed is filled last. Mine had a pinhole there.
Old 03-17-2008, 10:06 AM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi Dave,
A float level that is a little to high will tend to run a
little rich, A float that is a little to low will tend to run a little lean, this is because a high level takes less vacuum to pull the gas in, if some more info is needed check the link.
Rich
http://www.edelbrock.com/automotive_...all/1000.shtml
Old 03-17-2008, 11:51 AM
80%+ probability it is because you haven't fixed the fuel pressure yet....at 7.5psi the fuel liquid pressure "overpowers" the floats capability to stay closed when the bowl is just full....so gas just keeps pouring into the carb and into the motor and that is gaureeeeenteed to make plugs black and terrible mpg (and your timing was way to low for the cam in the other thread)
gotta fix that before you do anything else to tune the motor (on your other thread)....4.5psi is good...5.5psi is max
with correct pressure, if the floats are set wrong you will know it just driving...almost dies turning a corner or other symptoms listed on the trouble shooting page of the manual...
A quick question about titles and legal stuff. rusty105 Hotrodding Basics 71 05-04-2007 09:13 AM
Carb spacer question Gametech Engine 5 05-21-2005 10:04 PM
Barry grant carb air/fuel question Ratoflic Engine 8 05-10-2005 04:51 PM
a quick carb question... gt2betubbed General Rodding Tech 3 07-03-2003 07:20 AM
carb question mightycaminotw Engine 2 11-29-2002 08:05 PM
