Quick Change Rear Ends - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2012, 06:52 PM
I want to use a quick change rear end on my next build. The ones for racing generally cost half what ones used for the street cost. I know some designed for racing have different length axles. Can any designed for racing be used for the street?
Old 07-09-2012, 07:16 PM
as long as it has a " posi chunk" or "carrier" and not a" spool "it can be run on the street if it has a "spool" it is not designed to turn corners there fore it will break the gears when you start turning corners
Old 07-10-2012, 02:37 PM
ericnova72's Avatar
More for Less Racer
The ones for racing have different housing ends and axles, along with different hubs and brakes.
Racing versions are full floating hubs
Old 07-10-2012, 03:49 PM
You can get a bare 60" assembly for use with 5X5 wheel pattern and a locker for $2000. The axles and hubs will cost another $500. You can only normally get a 4.86 or a 4.11 gear. A differential in place of the locker will cost a little more.
Quick Performance rear ends?? jwnova Transmission - Rearend 5 02-13-2011 03:29 AM
What's a quick change rear-end? Nightfire Hotrodding Basics 9 03-21-2005 07:25 AM
Quick change rear end dgkipp Transmission - Rearend 5 11-04-2003 10:20 PM
Quick Change Rear KA67_72 Transmission - Rearend 0 03-06-2003 06:52 PM
QUICK CHANGE REAR ENDS bichon Transmission - Rearend 8 12-18-2002 11:45 AM
