Quick Change value? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2011, 10:04 PM
BigRoy1978's Avatar
Quick Change value?
Have a winters quick change rear end, alluminum case, has wide 5 hubs and alluminum disc brakes, willwood hubs, all the axles and pieces...
Just wondering what would be a good price to ask for this?
any insight would help! thanks.
Old 02-25-2011, 10:29 PM
BOBCRMAN@aol.com's Avatar
If you were closer I'd tell you it's a piece of junk. But, I'll come take it off your hands for a couple of bucks!!
Seriously I haven't a clue on used price. My boss an I went to a swap meet once and bought a complete one with tubes but no ends for $250.00. Buy of the day.
Old 02-25-2011, 10:37 PM
BigRoy1978's Avatar
this one is all there, trying to get a price figured up cause i cant use it, and know its worth quite a bit to someone. better than buying one out of speedway for 1800-2800!
Old 02-26-2011, 10:53 AM
Is it aluminum or magesium?
Does it have a diff or a spool?
There are many options for the housing, some like heavy duty pinion bearings are mandatory for asphalt cars with 600+hp.
Does it have aluminum axle tubes which means dirt only.
You need to know the width as is. New tubes and axles is about $500 +labor.
Old 02-26-2011, 06:37 PM
BigRoy1978's Avatar
Not sure on spool or diff, its in an older dirt late model.
axle tubes are steel, has leaf spring mounts welded to them.
Ill see if I can get some more info before I head out in the morning.
Quick Change radracer43 Hotrodding Basics 5 12-05-2005 03:48 PM
Quick Change GSCHOOLEY Hotrodding Basics 1 11-30-2005 06:49 AM
More Quick change questions Lee Hulick Transmission - Rearend 2 08-31-2004 10:07 AM
quick change rear end D-MaN000 Transmission - Rearend 2 12-07-2003 09:31 PM
Quick change rear end dgkipp Transmission - Rearend 5 11-04-2003 10:20 PM
