Quick compression ratio guess? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-15-2008, 02:43 PM
I've got a 350, bored .030 over. I 've got the 14014416 305 heads that have supposedly been opened up for 1.94 intake valves. I don't want to pull the heads just to check, so I will have to take his word for it. I know these heads have the 58cc chambers, so that should raise the compression ratio a bit. Is there a quick and dirty formula I can use to determine the CR given the information I have? If I need more information, let me know and I will track it down.
thanks
stu...
Old 02-15-2008, 02:47 PM
Here's a compression ratio calculator.
http://www.bgsoflex.com/cr.html
Old 02-16-2008, 08:06 AM
bondo's Avatar
Ayuh,.....
You'll have to cc the heads because they've been altered,....
You need to know the thickness of the headgasket,....
You need to know how far down the bore the pistons sit at TDC....
And,.....
You need to know how big the piston dish is....
In other words,....
Unless you tear down the motor,......
You'll be lacking 4 of the 6 measurements needed to find the Comp. Ratio.....
Old 02-16-2008, 08:44 AM
Hehe, I kinda figured it wasn't going to be as easy as I had hoped. Not a big deal as I have more important things to concentrate on at this point. I realized once I started using the calculators that I could change my CR by a point and a half just by spec'ing a different piston. Obviously, I need some more information. I'm just going to run it as it is for now and we'll see what the future brings.
stu...
compression ratio compared to compression PSI squids1 Engine 14 12-28-2010 11:36 PM
max compression ratio on 89 octane gemini86 Engine 31 07-01-2005 03:35 PM
Compression Ratio with 64 cc heads & Federal Mogul Sterling 345np Houman SS '70 Engine 9 05-01-2005 11:42 AM
Compression ratio dubie Engine 3 06-25-2004 08:50 AM
High compression ratio pistons invincible Engine 6 09-22-2003 10:16 PM
