First I'd have to ask if it does it on IE too and if it's only a few websites or all of them. If they look wrong after say downloading them your comp screen resoulution has to be changed to fit the screen size.
Please send an example link so we can see if they are displaying properly also in our browsers, I have all of them on my comp. |
So, they are the same in IE. If I save a picture from the internet to my computer, the picture is still wonky. Yet pictures that I have imported from my Digital Camera seem fine.
For example http://www.dragtimes.com/images/5068...%20Supreme.jpg this cutlass's sail panel looks as tall as the trunk is long. Its like that for every picture online, pictures I posteda long time ago on a different computer which looked fine at the time, now look squished. Thanks alot! |
What version of windows?
I would agree that Only Racing is on the right track. You said you have a flat screen, what specific brand/model is it? Is it a lcd flat panel? Once we know that we can look up the correct resolution (desktop size) for the monitor and set (or verify) it is correct. |
Find out what your monitor resolution is in your user monitor's manual or on the box it came in. Then, minimize all applications, right click the desktop, select whichever tab is for setting screen size, then set it for your monitors resolution, ie 1440x990 or whatever.
At this point, everything will display in the proper aspect ratio. |
Some pics will come out alright and some will show stretched to fit your monitor. It all depends on the monitor resolution and your picture resolution. If you have a higher resolution pic it normally shows up larger and will be more in relationship to your monitor. It may be distorted somewhat, but not as bad as a lower resolution picture. I'm wanting to say the "size to aspect ratio" but not quite sure at the moment if that is the correct term. I downloaded a Caddy for wallpaper the other day and it made a heck of a stretch out of it. You also say that your monitor is square? Mine is wider than it is tall so that is the way it stretches. You can go into your settings by right clicking on your "Desktop", then click on "Properties. When you get to the next window, left click on the tab that says "desktop". Look to the right of that window and you will see an area called "position". It will probably say "stretch". If you change that to where it says "Center" it will bring the aspect ratio of your picture to normal, but it will leave a border around your picture. You can also click on the tab that says "Settings" then adjust your "Screen Resolution" in the window that pops up. By going "Less" will bring your wallpaper sides in but it will also change the size of web pages.
Here is a pic of the Caddy that I dropped onto my wallpaper. I just haven't changed it yet to something that fits
BMM - to change resolution/screen size you need to 1.Go into Control Panel, 2. Click on display, 3. Click on Setting then on the bottom left, you will see screen resolution - click on that and play around a bit. With a wide screen monitor, I'm not sure they are ever right in the 16x9 mode. I have Firefox on the desktop with a Samsung wide monitor - and my pictures look poor (I have a photo of my wife where she looks like she is about 300# except she is only about 135# in real life but on my regular screen laptop, they are fine - it also is running Firefox. I do need to spend some more time on adjusting the desktop since it is a much better computer - I built it myself with premium pieces. It was just upgraded with a new and faster CPU and motherboard and now the resolution is off - again.
Dave W |
Kevin45, BMM is talking about images displaying properly on the web browser, not the desktop wallpaper.
Irelands child, my advice is correct and simpler than going to the control panel, it does the same thing. Images will display with the correct aspect ratio on your screen if you select it from the menu of available resolution choices. If your resolution is not listed, you need to use the driver disk that came with the monitor. |
Blues will tell you too, that it's a fast track in that way, the wallpaper thing is just change to center instead of fit or stretch. You can tell this by the size of the folders in your screenshot, which is correct. |
| Quick help with paint question. | 13th_Disciple | Body - Exterior | 16 | 07-29-2005 08:33 AM |
| Quick oil pressure question. | oldschoolrods | Engine | 8 | 05-11-2005 08:51 PM |
| Quick Application Question. | MontegoMX | Body - Exterior | 4 | 03-14-2005 03:15 PM |
| quick nascar question | 67bird | General Rodding Tech | 4 | 05-24-2004 08:54 PM |
| Quick question on timing an engine? | ATMRacerTX | Engine | 8 | 12-17-2003 01:00 PM |
