Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Quick and dirty (and cheap) frame rotisserie.
Old 04-04-2013, 11:22 AM
33Willys77's Avatar
33Willys77 33Willys77 is offline
I did a simliar set up too. But one one end, I used a driveshaft ujoint. That took care of any binding that can happen when turning it over. Also, on the front, instead of taking the brackets to the frame, you could have bolted it to your spring perch. When I build frames like this, I plan ahead and have a couple of strong ears to bolt on the rotisserie.
