quick disconnect tranny lines - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-11-2005, 10:56 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
I have a 2001 Dodge Ram with the quick disconnect tranny lines. I purchased the tool to disconnect the lines. How do I reconnect them, do they just push back on, or do I use the tool to get them back on?
Old 05-12-2005, 07:56 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
lube them and they should push in.
Old 05-12-2005, 11:48 AM
bracketeer's Avatar
489 Lemans
thanks
I wanted to know before I took them apart. Once I got the top one off and seen how they worked it was quite obvious. I thought the tool spread the seal open. Now that i have it apart I see that it only spreads the locking teeth open.
Braided tranny lines and dipstick? Rubberman2003 Transmission - Rearend 2 01-28-2006 03:11 PM
TH350 tranny shifts to quick? "SLOWMOE" Transmission - Rearend 5 06-04-2004 12:28 AM
tranny lines wich to where?? mikeweyman Transmission - Rearend 4 03-13-2004 03:31 PM
This is a odd question about tranny to rad lines. Indian Transmission - Rearend 10 09-09-2003 12:39 PM
Quick tranny question HemmiGremmie Transmission - Rearend 1 09-27-2002 07:04 AM
