quick engine question - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Hotrodders' Lounge> Introduce Yourself
Old 12-12-2005, 05:54 PM
ok i have a quick question
will a 327 short block fit in a 1983 buick rivera
any comment will be helpfull thanks
Old 12-12-2005, 06:45 PM
Wiki Edits: 31
it won't bolt up if that is what you mean,and the trans won't work but yeah, you could get it in there. that is a V8/RWD configuration right, I'm not farmiliar with a riv above the '73 Model year ( last year of the boat tails ). if ya wanna be cool find a 401 Nailhead with the 400 auto trans, they were used in riv's in the mid 60's
Old 12-12-2005, 07:08 PM
BOBCRMAN@aol.com's Avatar
Not economically! Nor will a Nailhead. Your best bet is repair the present motor. 307 Olds??
Old 12-12-2005, 07:20 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
WELCOME TO HR.COM
If its has a Multi fit bell housing it would interchange better more info and some pictures would help
If you repost this in the motors/engine section you will get a better responce
SR66
"SlowRide66"
"Illegitimis non carborundum"
Old 12-12-2005, 07:21 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Welcome to Hotrodders, enjoy the site.
« new member | Hi, »
Valve Lash adjustment hiball Engine 36 05-11-2009 11:12 AM
Need Quick Help Plz - Engine Mounts Hot_Rod_Faith Engine 3 01-09-2004 10:52 PM
engine ruff spot question Jag Daddy Engine 3 12-15-2003 08:08 PM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
