-   -   Quick Fuel 30-125 125 GPH Electric Fuel Pump (http://www.hotrodders.com/forum/quick-fuel-30-125-125-gph-electric-fuel-pump-197304.html)
64gto71cobra 04-26-2011 09:13 PM
electric fuel pump help
i have a 64 gto im running a quick fuel 125 pump and i took the car out tonight for the first time since being restomodded after driving for about 10 minutes the car died[ i was idling when it died] no fuel in the bowl pump running low [no prime] turned off the key for 10 sec turned on the pump it primed drove home same thing happen in the drive way after a 2 min drive from the first time it died .the pump is brand new the fuel tank is stock it has #6 steel braided hose from tank to carb a procomp bullit reg a jegs fuel pressure gauge that reads 0 psi even when the pump fills the carb the pump is mounted on the right rear frame rail the car runs great when the pump feeds the carb [even though the gauge reads 0] the only other problem i also had was my alt was only putting out 12.1 volts i dont think that would cause the pump to lose its prime could it be the stock tank any help would be great thank you
ssmonty 04-27-2011 12:25 PM
Sock on tank pick-up collapsing? Slowly letting fuel seep back in when pump is off? Allowing just enough fuel to keep engine running for awhile? Try running fuel from pump into a test jar or bucket. Couldn't say about gauge. Obviously you have some kind of pressure, if only briefly, to fill fuel bowel.
ssmonty
