Quick Fuel 30-125 125 GPH Electric Fuel Pump - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2011, 08:13 PM
electric fuel pump help
i have a 64 gto im running a quick fuel 125 pump and i took the car out tonight for the first time since being restomodded after driving for about 10 minutes the car died[ i was idling when it died] no fuel in the bowl pump running low [no prime] turned off the key for 10 sec turned on the pump it primed drove home same thing happen in the drive way after a 2 min drive from the first time it died .the pump is brand new the fuel tank is stock it has #6 steel braided hose from tank to carb a procomp bullit reg a jegs fuel pressure gauge that reads 0 psi even when the pump fills the carb the pump is mounted on the right rear frame rail the car runs great when the pump feeds the carb [even though the gauge reads 0] the only other problem i also had was my alt was only putting out 12.1 volts i dont think that would cause the pump to lose its prime could it be the stock tank any help would be great thank you
Old 04-27-2011, 11:25 AM
Sock on tank pick-up collapsing? Slowly letting fuel seep back in when pump is off? Allowing just enough fuel to keep engine running for awhile? Try running fuel from pump into a test jar or bucket. Couldn't say about gauge. Obviously you have some kind of pressure, if only briefly, to fill fuel bowel.
ssmonty
which electric fuel pump to use? wave1957 Engine 2 07-12-2010 01:21 AM
Electric fuel pump to manual pump engine.. RookieRodder Hotrodding Basics 7 02-14-2008 05:28 PM
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
Quick Fuel Racing Fuel Pump camaro freak Engine 6 11-05-2006 08:52 AM
HELP QUICK Electric Fuel Pump Leaking 66 T-Bird Engine 4 06-06-2005 06:26 AM
