QUICK! I have ONE HOUR! Will this Intake work??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2005, 08:33 PM
Dizturbed One's Avatar
I found an intake on ebay for my car (I hope) but I don't quite know if it will work.
It looks to be almost exactly the same as my current intake, but it's a four barrel instead.
The guy lists it as a 440 intake, and says nothing of 383's or Fury's in any of his listings, although he lists a couple similar big block cars (such as the Satellite)
My car is a 65 Plymouth Fury with a 383 big block, currently with 2 bbl carb and intake.
I don't know much of anything about mopars, but I have a feeling this will bolt right up and give me no problems.
http://cgi.ebay.com/ebaymotors/ws/eB...549099501&rd=1
I hope you guys can help, because I would like to have this intake, and the bid is only 1 hour away from closure!
Sorry for my flood of topics today, but I'm REALLY trying to get this car together and running good before August.
Old 05-14-2005, 08:37 PM
NAIRB's Avatar
A 440 intake will not fit on a 383. The 383 is a B series engine, while the 440 is the RB (raised block) style engine. Because the block is taller on a 440, the intake is wider. They use the same heads, but different blocks.
Old 05-14-2005, 08:51 PM
thanks alot Brian
one more for the filing cabinet in my mind
Old 05-14-2005, 09:10 PM
Wiki Edits: 49
Check this one out. It should fit your needs and you have 3 days to make up your mind. 383 intake
Offenhauser Dual Port intake? 454C10 Engine 21 05-10-2016 04:52 AM
Porting intake manifolds, is it a waste of time? Mad Maggot Engine 25 01-06-2005 11:59 PM
Intake port matching. Help please 67 Deuce 4 Me Engine 7 12-12-2004 04:40 PM
Head recommendation - low HP w/LT1 intake Tim240Z Engine 0 07-08-2004 12:56 PM
polishing an aluminum intake, lot of work?? HotRodF100 Engine 11 05-28-2002 10:56 PM
