Quick oil question, 1978 Wagoneer - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2011, 07:46 PM
dion's Avatar
72 Chevy Cheyenne
Hey guys,
Just changed the oil in my jeep, rebuilt 360 with 70K miles. I noticed that when I start the engine, even when it's warm the oil pressure is really low for several seconds then goes up to normal pressure. It didn't do this before. I used 10-40, too heavy?
Thanks.
Old 01-29-2011, 08:11 PM
Dion, I'm pretty sure the oil is not the problem - are you sure you have the correct oil filter? It's been a while since I worked on an AMC but I believe the oil filter has a check valve in it to prevent the oil from draining back to the pan. If there is no check valve, the oil filter has to fill before oil can reach the gauge (this applies whether the gauge is manual or electric) causing a delay in the gauge reading. I've understand there are "off-shore" filters that are really poor quality. Hope this helps you ....... Dennis58
Old 01-29-2011, 11:55 PM
sqzbox's Avatar
My pipes are my music
X2 on that^^
I had that problem especialy in winter with my 350 and after reading up on filters, selected the Napa Gold filter with the Anti-drainback valve. Oil pressure starts building with the first fire of the engine. Another of my car's (an 03 GP V-6) used to rattle bad on first start in the morning when it started and ran straight to fast idle and made me sick to hear it. Switching from fram to Napa Gold solved that problem also. 10-40 should not be a problem in SD. I was born and raised there and know the weather.
Old 01-30-2011, 01:19 AM
dion's Avatar
72 Chevy Cheyenne
Thanks guys. That could be it. I had a Napa filter #21522 in there but didn't know about the check valve and bought a filter from Car Quest. I'll try a Napa filter in there tomorrow and see what happens.
Dion
Old 01-30-2011, 01:21 AM
sqzbox's Avatar
Good deal. Let us know how it works for you.
Old 02-01-2011, 09:38 AM
dion's Avatar
72 Chevy Cheyenne
I switched over to the Napa #21522 filter and it's much better. Pressure is almost instant. It's a little slow for the first couple of seconds but the gauge reads immediately. Thanks again.
Old 02-01-2011, 01:28 PM
sqzbox's Avatar
After putting one on my truck because of the same problem you had, I went straight back to Napa the same day and got one for my GP. I won't use anything else from now on.
Thanks for the update.
1978 Ford F250 3 speed detent question Siggy_Freud Transmission - Rearend 1 09-15-2010 11:57 AM
1978 Corvette L82 oil question Crazy-J Engine 6 03-17-2008 11:14 PM
New here with '76 Jeep Wagoneer ghinmi Introduce Yourself 1 07-31-2005 06:03 PM
71 Jeep Wagoneer black66 Suspension - Brakes - Steering 0 11-09-2004 11:30 PM
Wheels and tires question 1978 GM G-Body. z3pr Garage - Tools 1 09-19-2004 04:03 AM
