quick question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2008, 10:28 AM
quick question
How is oil brought to the head in a solid lifter application on a SBC??
Old 01-26-2008, 12:14 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Through the lifter and up the pushrods just like hydraulic. As far as an oil metering system etc. I can't tell you, never messed with'em.
Old 01-26-2008, 05:12 PM
just like hydraulic
Old 01-28-2008, 03:20 PM
So then what is the difference between a solid and hydraulic lifter?? That makes no sense.
Old 01-28-2008, 03:33 PM
RippinRon's Avatar
A solid lifter is just that solid, no plunger type thing (excuse the terminology).
Old 01-30-2008, 09:11 AM
the differ in solid and hydraulic lifters are the hydraulic is you adjust it passed the preload and solid you cant but solids are set with a feeler gauge and the others arent usually but they still oil the same though your oil pressure [oilpump] just like when you first rebuild an engine most mechanics take a drill and prime the engine before starting it so it want be a dry start and everything will be oiled good but with the drill you can see that without the motor turning over the oil will reach and come though the top of the pushrods.i like solid because i feel you get truer cam timing than you do with a hydraulic because hydraulic lifters will float at high rpm do to pumping up to much and not bleeding down soon enough as for non pumpup lifters they are not solid lifters but hydraulic and they too will float at high rpm some will not agree with that but that is from my experience and my opinion
Quick help with paint question. 13th_Disciple Body - Exterior 16 07-29-2005 08:33 AM
Quick oil pressure question. oldschoolrods Engine 8 05-11-2005 08:51 PM
Quick Application Question. MontegoMX Body - Exterior 4 03-14-2005 03:15 PM
quick nascar question 67bird General Rodding Tech 4 05-24-2004 08:54 PM
Quick question on timing an engine? ATMRacerTX Engine 8 12-17-2003 01:00 PM
