quick question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2008, 01:17 PM
quick question
Hey guys I am a little unfamiliar with rear end terminology so please forgive me. When you hear the terms (7.5", 8.5", 9") rear ends, does this reffer to the diameter of the ring gear?? If it does and I have a 10 bolt chevy rear end with a 7.5" ring gear, can I take it out to swap in an 8.5" ring setup or do I need to replace the entire unit?? Thanks!!
Old 03-14-2008, 03:51 PM
Holder350's Avatar
Auto Parts Professional
Sigh....
yes the size of the rear is determined by the diameter of the ring gear.
and no you cant put a 8.5" gear in a 7.5" case. its like trying to put a 4" ball thru a 3" hole, cant be done.
Quick help with paint question. 13th_Disciple Body - Exterior 16 07-29-2005 09:33 AM
Quick oil pressure question. oldschoolrods Engine 8 05-11-2005 09:51 PM
Quick Application Question. MontegoMX Body - Exterior 4 03-14-2005 04:15 PM
quick nascar question 67bird General Rodding Tech 4 05-24-2004 09:54 PM
Quick question on timing an engine? ATMRacerTX Engine 8 12-17-2003 02:00 PM
