A quick question?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2003, 06:41 PM
Stinky's Avatar
Suspended
A quick question??
I converted my 69 pontiac points sysem to HEI, which I pulled from a ventura. there were no wires to show anything. Where is the no. 1 tower on the distributor cap??
Old 06-11-2003, 09:21 PM
Bumpstick's Avatar
Hammer and a torch
As looking from the front of it the elongated rectangle shaped bump on top should be running from left to right and almost straight across (sometimes at a little angle...) Anyhow the very front 2 terminals are number 1 on the right and number 8 on the left side... Rotation is clockwise so its 1-8-4-3-6-5-7-2
If correctly installed with the balancer on TDC (on the compression stroke) the rotor pointer should be almost pointing at number 1 cyl...
Old 06-11-2003, 09:38 PM
Stinky's Avatar
Suspended
By elongated bump do you mean the coil??
