quick question! - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2002, 07:28 AM
Scuzzy's Avatar
Certified Cruck Lover
Post quick question!
Does anyone know if a th350 will bolt up to a '94 350?
th350 is in my 80 el camino (where the motor is going) the motor is out of a '94 z71
Old 10-12-2002, 04:51 PM
New Member
Post
It would depend on which bell housing (the last transmission) you have behind the engine!
Remember, GM products fit GM products!!
Old 10-12-2002, 05:59 PM
Post
The trans should fit the engine you have without a problem. The only possible problem I see is a starter/flywheel incompatibility which is easily handle at your local parts store.
