quick question on a couger - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2006, 12:11 PM
i have a 85 couger with a 5.0 that im useing as a parts car for my mustang. does it have a 8.8 rear end? that is pretty much all i need to know. if you know the gears in it that would be nice but most likely changing those anyways ty.
Old 09-01-2006, 10:00 PM
Should be a 7.5" rear end. Look at the cover plate. If the top & bottom are flat, and the sides are curved, it's a 7.5". The 8.8" has 4 flat sides. It also may be wider than a Mustang rear end. Early '85 Cougars & T-birds used a Mustang-width housing, but longer axles and offset brake drums. In mid-'85, they went to a rear end with a wider housing & flat-sided drums. It probably has 2.73 gears if it's the original.
Old 09-02-2006, 07:12 AM
pmeisel's Avatar
Glad the Jeep is on the road
Last wiki edit: How to identify a Ford V8
http://www.coolcats.net/tech/general/axleinfo.html
Check this link out, probably more than you need to know.
Old 09-02-2006, 12:10 PM
thank you for the information ill continue looking into it thanks again
Quick help with paint question. 13th_Disciple Body - Exterior 16 07-29-2005 08:33 AM
Quick oil pressure question. oldschoolrods Engine 8 05-11-2005 08:51 PM
Quick Application Question. MontegoMX Body - Exterior 4 03-14-2005 03:15 PM
quick nascar question 67bird General Rodding Tech 4 05-24-2004 08:54 PM
Quick question on timing an engine? ATMRacerTX Engine 8 12-17-2003 01:00 PM
