quick question hands dirty - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-13-2008, 01:59 PM
when lining up a 9 keyway chain set and i want to run it at +6 degrees do i still line up the two regular dots on the chain with the crank on the +6 keyway?
Or do i line up the dot on the cam gear with the +6 on the crank gear tooth?
Old 10-13-2008, 02:13 PM
Dot on cam gear facing down in the 6 o'clock toward the crank.
The crank gear has two sets of indicators, the one on the inside aligns with the amount of desired advance or retard to the key position when the crank has number 1 and 6 at TDC. The outer row of numbers is aligned properly when the desired amount of advance/retard number is facing the cam dot.
The number over the key and the number pointing at 12 O'clock toward the cam dot must be the same number.
Bogie
Old 10-13-2008, 02:18 PM
so if im understanding u correctly the cam gear dot at 6 o'clock as normal
and the crank on the +6 keyway with the +6 mark on the crank gear tooth at 12 o'clock
this should advance the cam 3 degrees right
Old 10-13-2008, 02:23 PM
Yep, keep in mind that the SBC in this position is set to fire number 6 not number one, so before you close things up rotate it so the crank gear #6 mark is at 12 o'clock and the cam gear dot is also at 12 o'clock. It is now ready to accept the distributor to fire number 1.
You probably already know that, but dadgumit, we always get bit by that one.
Bogie
Old 10-13-2008, 02:29 PM
thanks for the help bogie!!!
Quick help with paint question. 13th_Disciple Body - Exterior 16 07-29-2005 08:33 AM
Quick oil pressure question. oldschoolrods Engine 8 05-11-2005 08:51 PM
Quick Application Question. MontegoMX Body - Exterior 4 03-14-2005 03:15 PM
Quick question on timing an engine? ATMRacerTX Engine 8 12-17-2003 01:00 PM
I have an 1986 firebird trans am, quick question Nightrider86 Body - Exterior 1 12-08-2002 08:31 PM
