Quick question on scuffing metallic base before re-shoot - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-17-2010, 02:50 PM
Shot base yesterday and am past my 7 hr window. Need to scuff up the base. The base is metallic. I'm wondering if I need to use pads ( if so what kind ) or if I can use 800 grit on a DA.
Thanks
Old 07-17-2010, 09:01 PM
Rag top bird's Avatar
Hot rods are still the king
I would wetsand with 800 and re apply the base
Old 07-18-2010, 06:50 AM
deadbodyman's Avatar
Wiki Edits: 11
a red scotch brite scuff pad would be fine.when you hit a piece of trash just nib it down with dry 400 wet sand paper...takes about 30 min...depending on the brand of paint it'll take two to three more coats...
Old 07-18-2010, 01:35 PM
Countilaw's Avatar
Cox Custom Cars
Unless you are two or three days past your window, you can still shoot on top of the base.
The manufacturer is just covering their ***** with the 7 hour window.
Painting custom paint jobs, we sometimes go three days with graphics and trim before we shoot the final coats of clear. Never had a problem yet.
Frank Cox
Cox Custom Cars
Old 07-18-2010, 06:13 PM
What basecoat has only a 7 hr window? Most I've seen normally range somewhere from 24-72 hrs.
Quick primer/top coat question loyter Body - Exterior 4 07-20-2006 12:40 PM
Dupont base question hemi43 Body - Exterior 1 05-24-2006 09:39 PM
Merry Christmas all and quick tool question Classix_Lover Garage - Tools 7 12-25-2005 05:02 PM
quick engine question kelly marie Introduce Yourself 4 12-12-2005 07:21 PM
Metallic BC/CC question babyface Body - Exterior 14 05-25-2003 08:39 PM
