Quick release coupler before filter bad idea? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-25-2005, 03:32 PM
Last journal entry: final pics of first engine swap
This is for my 2nd drop, about 55 ft away. I thought I had a good idea putting a 3/8 hi flo coupler on top of the F88, so later I can quickly just take 2 bolts off and take the whole thing down to take apart the 4 small bolts to dissassamble and clean filter or have another duplicate cleaned & ready to put up, now thinking maybe this thought was just plain silly?
I'm worried Im messing with the air flow going from the 3/4" L copper pipe to a really small 1/4" with the npt fittings restricting just before the water seperator.
I can go directly from 3/4" to 1/2" right onto the HF filter like I plan to do on drop 1 like this for example.
Its missing the regulator since I'm using it on the Sharpe. Got one more coming just for another regulator on it. Couldn't beat $20 also to have a backup filter too.
Should I skip the quick release coupler before filter idea?
Old 11-25-2005, 03:48 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Just use a pipe union..those can be unscrewed if needed..
OMT
Old 11-25-2005, 04:18 PM
Cool, just needed some direction. Cant believe I thought myself a simple union wouldn't work. Was thinking once you loosen, you start tightening whats behind, I thought it be an added on inconvienient union piece in the way. I just need to go look at some more different unions
Well at least heres some pics of the progress, thanks to this site is where I picked up so much of the addicting info from. Heres where alot of you folks have helped me get to.
The point of no return (good thinking or bad idea?) 409guy Body - Exterior 9 03-11-2013 05:28 PM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 06:52 PM
307 + t400 5speed good idea or bad 88camaro Transmission - Rearend 2 11-15-2003 10:35 PM
Are painted intakes a bad idea? gearhead77 Engine 6 10-19-2003 07:55 AM
Good or Bad Idea? drlindz Body - Exterior 8 10-01-2003 10:53 AM
