Quick TBI question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2007, 09:30 PM
Quick TBI question
could the distributor have anything to do with the fuel injectors not firing?
Old 06-10-2007, 09:32 PM
if its not firing its not going to spray fuel, test your module and if that aint it its the coil whats it on 2
Old 06-10-2007, 09:43 PM
well the engine is turning over it just wont spray gas, but when we took the coil wire off the coil and stuck a screwdriver and stuck it in there and grounded it it only sparked like twice and thats it, its on a 1991 camaro rs but we just dropped a 350 in it and it just wont fire up bc of an apparent fuel or spark problem...
Old 06-10-2007, 09:49 PM
have u cracked fuel line to see if u got fuel to the throttle body
Old 06-10-2007, 09:55 PM
yeah the fuel is making it all the way up the fuel lines, we swapped injectors and when the fuel line came off fuel was coming out
Old 06-10-2007, 09:57 PM
make sure u got fire to your distributor cause i had the same prob when my module when out on my1990 350 and it wouldnt spray fuel i ended up replaceing the module and coil, but autozone or oreillys can check that module.
Old 06-10-2007, 10:07 PM
well we noticed that the top of the coil had a few chunks knocked out of it, but did getting a new module and coil fix the problem?
Old 06-10-2007, 10:27 PM
yea it fixed it
Old 06-10-2007, 10:30 PM
ok thanks for the input
Quick help with paint question. 13th_Disciple Body - Exterior 16 07-29-2005 09:33 AM
Quick oil pressure question. oldschoolrods Engine 8 05-11-2005 09:51 PM
Quick Application Question. MontegoMX Body - Exterior 4 03-14-2005 04:15 PM
Yes, a quick stroker question joeyg329 Engine 2 06-30-2004 08:29 AM
quick nascar question 67bird General Rodding Tech 4 05-24-2004 09:54 PM
