Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Quickfuel 750 SS Super Rich at Idle
Old 03-12-2012, 03:26 AM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Do not start messing with the carb untill you have corrected the timing.
14deg is not near enough.
22 tp 26deg at idle minimum . Locked out timing (34-36deg at idle) is not too much.
Then reset the carb throttles. 4.5" power valve.
