Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Quickfuel 750 SS Super Rich at Idle
Old 03-12-2012, 11:43 AM
grannysbird grannysbird is offline
Well, yeah it would appear the transfer slots are far off from square. How many thousands do I want exposed on each side?
Pictures are below.
Underside of Carb
Power valve sizing is based on engine vacuum correct? And if the valve comes on too early I'll be pumping too much fuel at the wrong time leading to an overly rich condition correct?
Concerning timing the thing won't start or run at all too far outside of 14 degrees initial. Also it's running so rich that I can't adjust the timing without the thing loading up and dying, and 22 to 26 degree's advance at idle? That seems very high for a ford, if you don't mind my asking why is 14 degrees initial not enough? If I had 22 to 26 advance at idle that would put me in the 40's with the mechanical advance...
