quiet down noisy external electric fuel pump - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 12-29-2013, 06:04 AM
i went as far as mounting the pump in a small metal box and filled the box / air gap with spray foam, it did not work.
  #32 (permalink)
Old 12-29-2013, 07:23 AM
Banned
mounting a pump in the tank is not hard, nor is it $$$$$$$$$$..
see this is a 67-68 firebird fuel tank sender, most likely a 67-68 Camaro also..
anyways see where the feed tube with sock filter.. remove the sock.. cut some of the line after the 90* bend to try and keep the feed as close as the factory sock.. even if you need to have a u turn after the pump and the sock beside the pump
install the pump(not the one you have) wrap the pump body with a small 1" long piece of boat exhaust rubber pipe(fuel won't hurt it and it'll keep the pump from buzzing against the floor of the tank , only needed if pump bought doesn't come with it's own rubber part) and put the sock filter that comes with the new pump on the feed end.. run the power wires up and through the sender base.. most walbro intank kits come with the grommet for the wires to pass through and seal the tank. and weld the feed line at the sender base(ring tank mount) as the solder won't cut it..
or make the oem feed the return,.. get an a/n bulkhead fitting, drill hole in tank. connect a/n line to inside half of bulkhead fitting and mount fuel pump to that.. 1999 grand mark/crown vic pumps will work but you'll need a regulator to bring the pressure down to the tbi 15-18 psi.. or use a walbro.. the pumps mostlikely less than the carter installed in it now.. and the a/n bulk fitting and fittings and line are maybe 30 bucks.. mounting it to the oem feed tube is maybe 5 bucks if you don't have any steel tubing/line hanging around.. and the pump power grommet is as cheap as a junkyard away.. no NEED for a custom tank.. unless this was a corner carver.. and needed the fuel to not run away from the feed line.. this is an hour job tops.. once you drop the tank.. it's so easy.. it's not even funny..
  #33 (permalink)
Old 12-29-2013, 12:17 PM
EOD Guy's Avatar
If you don't fashion some type of anti-slosh baffle to surround the pump pick-up you might experience pump starvation during cornering on a tank that's low on fuel.
  #34 (permalink)
Old 12-30-2013, 01:25 AM
Banned
and that's any different from the pump outside the tank, how..
easy fix, don't go below 1/8 tank.. besides you shouldn't get that low anyways the fuel cools the pump..
  #35 (permalink)
Old 12-30-2013, 03:32 AM
EOD Guy's Avatar
The "how" would be...... on a out side the tank pump, the pickup is small and normally has a screen/sock attached to it and rests near or on the bottom of the tank....only needs a small amount of fuel to keep the 3/8 line full.
On an in tank pump the actual pickup opening on the pump is located 1/2" to 2" above the bottom of the tank using some sort of stand-off and needs a little more than the 1/2" to 2" of fuel in order to keep the pump supplied. All modern tanks that I am aware of, have a baffle or open cell foam in the tank that surrounds the pickup preventing pump starvation during cornering.
As you mentioned above it's easy to convert a tank to an in-tank pump, and just as easy to attach a baffle to the pump using a SS hose clamp and a piece of galvanized or SS exhaust tubing. Just as easy to modify a junked in tank pump/sending unit flange to just about any vehicle, simplifying the line and electrical connections. Simply trim the donor flange to fit within the orig flange footprint (make sure the locking ring can still engage), cut a hole in the orig flange, weld the trimmed donor flange to the orig flange.
  #36 (permalink)
Old 12-30-2013, 07:14 AM
Banned
maybe the way SOME are done.. but I've always place the sock as low as the stock set up did.. no change.. if the pump inlet is centered on the pump and the sock goes on it. I add to the inlet to get sock on the floor..
  #37 (permalink)
Old 12-30-2013, 03:45 PM
EOD Guy's Avatar
I understand you don't think anti-slosh baffles are necessary but I think they have a purpose and should be considered when converting an old tank to an in-tank pump setup.
  #38 (permalink)
Old 02-27-2014, 01:14 PM
cavitation
I think the high pitched whining noise is due to cavitation as one member mentioned. On my car which started out in life as a 70 Buick Electra 225 with a 455 wildcat, and rapidly became a Rolls Canardly when I started using my tig welder, I turned the gas tank from flat to upright. We put on a Throttle Body injection with a carter pump. The return line went to a tee located between the tank and pump. This was a mistake as the fuel recycles without cooling and the alcohol in the fuel starts the vanes cavitating as soon as it heats up. Engine cold and fuel cold >> no whining noise. Engine hot and fuel hot >> whining noise. I have a spare fitting on the tank so the return line now runs to the tank and has to heat up all the fuel before whining starts. So far, so good. My friend tells me that any obstruction in the pickup line will also cause whining which makes sense as it is pulling a partial vacuum >> cavitation. I hope this helps.
  #39 (permalink)
Old 02-27-2014, 06:11 PM
EagleMark's Avatar
GearHead-EFI.com
Good info! Hope it helps!
There's also a couple different designs for pumps. The Carter is a better pump but it is Vane drive like the aftermarket high performance pumps and they are noisier. The other is an impeller drive and quieter.
With external pumps there is supposed to be a filter before the pump. Using a clear carb filter is a good choice and can see if there is any debris or water settling in bottom. Remove in tank sock when plumbing this way.
The micron rating of a carb filter is much higher then a Fuel Injection filter! So you still need a EFI rated filter after the pump and this seems to make no difference in noise.
If you run a Metal can Fuel Injection filter before the external pump it is nosier! If you run a sock in tank, without the pre pump filter, it is quieter!
External pump closer to tank is also quieter! Less suction...
So my findings are similar and has a lot to do with placement of pump and the amount of Sucking it has to do! They like to pump, not suck! This falls over to the fuel line used before the pump. Fuel line is for pressure and I have seen some cheaper quality carb fuel line collapse with the suction needed to supply fuel needed.
  #40 (permalink)
Old 06-21-2016, 09:50 PM
So I had this problem too. I read the forums and couldn't find anything on it so I decided to try a few things. First thing I tried was another one of those little rubber flat pieces that come with the pump. That didn't help. Next I tried a piece of pamper tape between the pump with the rubber pieces... That helped a little but not a lot. It was still very noisy.
So here is what I did and it took about 75% of the noise away. I also took some pictures. The installed pictures will come tomorrow because it was night time and I couldn't get a good picture on the phone.
Basically what I did was. I was thinking about putting a grommet between the pump and the body. As I was looking thru my box for some grommets I ran across a Hood bump stop. It had a small hole in it and it was about 1/4 thick.
So I cut the part off thhat goes into the body of the car giving me a flat rubber piece with a whole thru it.. The hole was too small for the bolt to go thru, so I drilled the hole out with a 1/2 drill bit. I did this with 5 more for a total of 6.
I got a longer bolt (2.5 inches), a nut and 2 washers. I put 3 of the rubber bumpers on the bolt. So basically it looked like this. Bolt head, washer, bumper, pump bracket, bumper, frame, bumper, washer, nut.
I will post pictures of all of this including the part number to the bumpers I used but for some odd reason my PC is not letting me upload to this site.
  #41 (permalink)
Old 06-21-2016, 11:32 PM
Location: in the land of Trolls at least till the san andreas releases the big one
the only thing not said... is
MAGNETS inside the fuel tank to keep the sediment out of the pumps.. both mechanical and electric.
  #42 (permalink)
Old 06-23-2016, 07:30 PM
Originally Posted by CraigsClassics View Post
I installed a '89 Camaro RS+ 305 TBI/700 R4 in a '67 Firebird Convertible. Used the Painless aftermarket wiring loom & factory ECM to manage everything. Had to install an electric fuel pump & have a return-line in the gas tank for the TBI. Use a Carter P5000 pump & works well. Only problem is it's really noisy, especially with a convertible as it runs all the time. Anyone had the same problem & come up with a way to quiet down an external fuel pump that's mounted back by gas tank on frame rail. A submerged pump system is alot more $$ & the stock gas tank would also have to be either modified or replaced with a custom....more $$$.
Are you using a bypassing regulator?
The pump is probably delivering far more fuel than the engine is using. If you aren't using a bypass regulator then the pump to a some extent from large at low RPM to less at high RPM is dead heading that is pumping against a pressure that shouldn't be there. A bypass regulator has a return to the tank or to the inlet side of the pump. Any fraction of fuel not being used by the engine returns so the line pressure between the pump and regulator is no longer the "stall pressure" of the pump running at full capacity and the engine demand being something less than full pump capacity.
Some pumps have internal bypass regulation built in it usually isn't enough on one hand and since if just routes the fuel back to the inlet side the arriving fuel has a frequency instilled by the pump than then forms a beat frequency when reintroduced at the inlet side. This is why a bypass return to the tank or an accumulator before the pump works much better at holding the noise down.
Bogie
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
external electric fuel pump sbc 350 vapor lock problem Syn77 Hotrodding Basics 8 10-16-2011 09:46 AM
Quiet electric fuel pump ? western star Engine 24 02-05-2010 08:43 PM
Wanted: QUIET 12V electric fuel pump for carb'd 350HO Deluxe 38Dodgebiz General Rodding Tech 12 01-01-2010 11:54 AM
Best external fuel pump for a TBI 350? nat Engine 3 03-30-2007 01:28 PM
Noisy Electric Fuel Pump lakecityg Engine 2 07-05-2003 12:41 PM
